Problem in reading XML file
  • Oct 17, 2014 2:48 PM UTC
  • 104 views
I am very new to xml and when I want to open my xml file, I have a reader in navigator but no feature types appear. In log file I receive this message:
<R_1 Reader> - No GML features were found in the set of XML Schemas, make sure that at least one of the schemas is a user, domain or community-specific "GML Application Schema".
UniversalReader -- readSchema resulted in 0 schema features being returned
Reader Parameter(0) = >C:/Users/TEMP.GIS.000/Downloads/codelists-1.0-examples/codelists-1.0-examples/BuildingFuctionType.xml<
Reader Parameter(1) = >MAP_EMBEDDED_OBJECTS_AS<
What I need in my workspace is to have the building types and  their values for further work.
<dictionaryEntry> <gml:Definition gml:id="id21"> <gml:description/>
<gml:name codeSpace="urn:d_nrw_sig3d">1000</gml:name>
<gml:name>residential building</gml:name> </gml:Definition> </dictionaryEntry>
I don't know how to configure the reader to read this xml. Is there any idea?
Thank you in advanced!
Best regards,
Mani
P.S. the xml is located in:
http://schemas.opengis.net/citygml/codelists/codelists-1.0-examples.zip/BuildingFunctionType.xml
Best answer by fmelizard
Hi Mani,
When using gml:Definition as element to match I end up with a list (name{}) in which the attributes name{0} = numeric and name{1} = description are present for each gml:Definition tag (n=19 for the \\BuildingClassType.xml file). After that its a matter of copying them into attributes so that they are available downstream or using the list elements.
fmelizard
Forum|alt.badge.img+22
  • Oct 17, 2014 4:37 PM UTC
The 'normal' way of parsing a XML file is to specify a feature type in the readers parameters.
In your case that would be : dictionaryEntry, this will return all attributes belonging to the feature type.
Check FMEpedia (http://fmepedia.safe.com/fmeSearch?q=xml%20reading)for resources on XML reading, always a good place to start.
Itay
  • Oct 19, 2014 10:13 PM UTC
Hi Itay,
Thank you for your help and tips. <dictionaryEntry> <gml:Definition gml:id="id21"> <gml:description/>
As you see here I need just to deal with the information in gml:name. So I decided to focus on gml:Definition instead of dictionaryEntry. Actually I expected to have a list for name in my attributes (name{}). I tried different Element to match but in all the cases if I want having "1000" and "residential building" in two attributes I have in one row 1000 and in the next residential building.
For example I used "gml:Definition/gml:name/" (and many others) in Element to match.
Do you have any idea what can I use to give me the non/-numeric values in separated attributes?
Best regards,
Mani
fmelizard
  • Oct 20, 2014 6:41 AM UTC
Hi Mani,
  • Oct 20, 2014 7:16 AM UTC
Thank you Itay for youre great help!
