PostGIS Reader - warning about 3D feactures
  • September 25, 2024
  • 70 views
lambertus
Forum|alt.badge.img+16
I created a 2D spatial point dataset in a PostGIS database.
Today I tried to load them into FME, that works perfect. I get the right locations including the according attributes.
I only get this warning:
Dimension metadata is ambiguous for spatial column 'geom'.  Reporting 3D when 2D+measures might be present
Did I forget to set some specific settings while creating this dataset? There should be no 3D data present, I only saved 2D data :)
crystalatsafe
Forum|alt.badge.img+19
Hi @lambertus
I'm sorry that no one has responded to your question yet!
Can you send a screenshot of that warning? Please also include a few rows above the warning in the screenshot. :)
Crystal
lambertus
  • November 22, 2024
Dear ​@crystalatsafe, it took a while but the error popped up again. Find attached my log file which shows the error. In this case I used polygon data as input using a FeatureReader connecting to a PostGIS database.
When needed I have the complete log file saved as well.
crystalatsafe
Hi ​@lambertus
I'm sorry for the late response.
If possible, can you share your workspace with some sample polygon data? Can you also send your workspace template with feature caching when the warning appears?
We would be happy to look at what might be causing this warning.
Crystal
