PDF Writer with more than A3 paper size
  • Mar 8, 2016 9:11 AM UTC
  • 5 replies
  • 117 views
pratap
Forum|alt.badge.img+12
I have to convert dwg files to pdf in a batch mode, but it seems the paper size is restricted upto A3. Is there any option to increase the paper size.
Pratap
Best answer by david_r
Here is a screenshot that shows where to input the point sizes:
This creates a paper size of A2.
  • Mar 8, 2016 9:18 AM UTC
Hi
From the help:
You can select preset page sizes for common paper sizes or specify the page size in PostScript points in the format <width> <height> For example, 612 792 is a letter-sized page.
A PostScript point is 0.35278 mm, so it should be easy to adapt the width and height to any paper size with some simple calculations. There is also a handy little reference here.
David
pratap
  • Mar 8, 2016 9:20 AM UTC
I read this sentence... But I didn't understand in which attribute does this height and width has to be replaced
Pratap
  • Mar 8, 2016 9:23 AM UTC
pratap
  • Mar 8, 2016 9:28 AM UTC
Thank you...
Pratap
Hi
From the help:
David
I also found a handy calculator for lots of common paper sizes here. Select "point" as the unit to get the values you need.
