pass java parameters without env variable
  • Apr 29, 2020 2:45 PM UTC
  • 0 replies
  • 26 views
Hello!
I found a way to configure a JDBC connection using env variable but unfortunately, it breaks another software configuration I have on the same Windows machine. My goal is to set the following configuration:
JAVA_TOOL_OPTIONS=-Djava.security.auth.login.config=...
I felt like it was possible to directly configure the attached JRE (like in jre\\lib\\security\\java.security file) but it doesn't seam to work. Since I am running the fmeworkbench.exe, how can I pass the configuration to the program? Is there a config file which is read (seams to be the case for the server)?
Many thanks for helping and wish you a great day!
Christophe
