My Tiff/geotiff writer will not write any world files or tab files
  • Jul 30, 2018 2:20 PM UTC
  • 9 replies
  • 121 views
bjudes
Forum|alt.badge.img+10
I have Feature Reader that pulls tiff files, these are then passed on to the Geotiff writer. I now want the writer to write the tiffs, with the world files. I have selected within the writer to include world files but it is not working. I've uploaded the workspace.
Thanks for any help.
Bjudes
Best answer by bjudes
Update. I got it to work, I didn't have the Schema output port from the feature reader attached to the writer. This stopped the tfw/tab writing. Thanks for your help.
bjudes
  • Jul 31, 2018 7:04 AM UTC
Has anyone got any ideas on this, would appreciate any help. Thanks
Forum|alt.badge.img+63
I noticed that the FeatureReader is currently set to use the TIFF reader, what happens if you change that to GeoTIFF?
If that doesn't work, inspect the data coming out of the FeatureReader and doublecheck whether it's acutally georeferenced.
bjudes
  • Jul 31, 2018 8:44 AM UTC
Thanks for the answer. Changing to GeoTiff doesn't make any difference. I also tried inspecting and the images are georeferenced. In the log file (attached), you can see that it is reading the .tfw from the original folder. Any ideas? Thanks for the help, I really appreciate it.
B
logfile.txt
B
logfile.txt
Could you also post the end of the logfile, i.e. where it's writing?
bjudes
  • Jul 31, 2018 9:35 AM UTC
logtext2.txt
Please find it attached. Thanks B
logtext2.txt
Hard to say... I would try removing and re-adding the writer, see if that fixes it. I'm also wondering about the notifications you get when writing, maybe that's something Safe's support should look into.
bjudes
  • Jul 31, 2018 10:32 AM UTC
I said I'd try and write to JPEG to see if I'm having the same problem. Within the log file I get this warning
2018-07-31 11:30:04| 20.2| 0.0|WARN |JPEG writer: Some georeferencing information may be lost when writing to this format. Consider writing a world file to preserve this information
I have checked to write a world file, just like last time.
Removing the writer doesn't work, I've tried that. Thanks for all your help.
B
bjudes
  • Jul 31, 2018 1:25 PM UTC
logtext2.txt
bjudes
