Importing spatial data into PostgreSQL
  • Aug 7, 2015 1:36 PM UTC
  • 60 views
Hi all,
Does anyone know how to import spatial data into Postgre? It seems  the option Allowed Geometries is greyed out.
Thanks,
Darius
Best answer by david_r
Hi
The PostgreSQL database isn't spatially enabled unless you also install the PostGIS extension. You can then use the FME PostGIS reader/writer.
David
  • Aug 7, 2015 2:20 PM UTC
Hi
David
Hi
David
Hello @david_r
I'm looking into this issue right now. Can you elaborate a bit more of how to install the postGIS extension? I am not getting much info online...
nielsgerrits
Forum|alt.badge.img+67
Hello @david_r
Run the Stack Builder and choose the version you need under Spatial Extensions.
See this post on Stack Exchange.
More details can be found here.
  • Nov 16, 2017 7:51 AM UTC
Hello @david_r
This is the first hit if you google "install postgis extension":
http://postgis.net/install/
Follow the instructions under "Getting started", on the right hand side.
