how to transformer polygon of postgis to autocad
I have table of polygon from PostgreSQL and i would to transform polygon to autocad so i use fme desktop to generate autocad but when generate autocad i don't get polygon of the pacelle i get just point of the polygon PostgreSQL
fme
autocad
help me please
  • January 16, 2017
Hi
The problem in your case could be that you have more than one geometry attribute.
Benjamin
itay
Forum|alt.badge.img+18
  • January 16, 2017
can you share the data?
  • January 16, 2017
I propose you to read the database as postgres reader instead with postgis reader. This way you have all the geometry attributes visible in the reader dataset. Then you can add a GeometryReplacer and pick the right geometry attribute. Geometry encoding normally is 'Hex Encoded OGC Well Known Binary'.
thanks
