How can I fix the Annoation scale to readable ?
  • Jul 24, 2025 2:29 PM UTC
  • 134 views
probert1968
Forum|alt.badge.img+5
I am working on a lot of the DWG we got from a contractor and I have to deal with it because our forest is using a different projection and the units are different.  However, I have no troube with write to a new DWG with the correct projection and units.
The only one probem I have here  is the Annotation which is different between the FME Data Inspector and ArcGIS Pro I have here.  The Annotation scale is way big and all over that I cannot read in ArcGIS Pro.
Is there a work around to fix the problem ?
I am in Colorado and work for a forest service.  I have two screenshot that will be helpful
This picture is in FME :
and this is in ArcGIS Pro
Can anyone out there that have had similiar issues or a problem solved in the past ?
Thanks !
crystalatsafe
Forum|alt.badge.img+32
​@probert1968
If possible, could you please share your workspace with sample data or share a screenshot of your workspace and a screenshot of how you set up the writer?
It might help to use a Scaler transformer.
probert1968
  • Aug 6, 2025 7:05 PM UTC
Thank you !
Sure
Original done by an Autocad User :
After I save them to a new DWG with new coordinate system , this is what I get
So, that is why I am asking to see if there is a way around…
crystalatsafe
Hi ​@probert1968
Have you tried the Scaler transformer?
Could you send a screenshot of your FME workspace and how you set up the writer in FME? Which version of FME are you using?
You could try the suggestions mentioned in these related community posts:
Scaling AutoCAD Annotative Block
How do workout the model space Annotation Scale in FME?
