Hi I Am new to the geopdf translation I would like to have an entire feature table of oracle spatial converted to geopdf with each record as a separate layer .Currently fanning out by one of the attribute creates new file
  • Apr 29, 2014 2:19 AM UTC
  • 32 views
Hi I Am new to the geopdf translation I would like to have an entire feature table of oracle spatial converted to geopdf with each record as a separate layer on the basis of an attribute .Currently fanning out by the attribute  creates new file
Best answer by gazza
Hi Roy,
Are you doing the fanout on the Writter (under Parameters > Advanced) or on the Feature Type (under Feature Type Properties)?
The first will create new files for each record whereas the second will create new layers in a single pdf.
Regards
Gary
gazza
  • Apr 29, 2014 2:38 AM UTC
Hi Roy,
Regards
Gary
