I'm using the validate Output File option on the GML writer in application schema mode.
i can see in my workbench log the number of fatal errors, errors and warnings it finds.
But it doesn't fail the translation when it detects errors.
How can I configure it to fail when validation finds errors?
I'm testing in FME desktop and this workbench will be deployed to FME Server in production.
example messages in log:
<GML_1 Writer> - Setting external schema location for validation 'D:\\temp\\GML_Validation/myschema.xsd'
XML Validation: Error in 'D:\\temp\\GML_Validation\\output.gml' on line 11, column 40: 'value '1.11' does not match regular expression facet '[+\\-]?[0-9]+''
<GML_1 Writer> - Found '0' fatal error(s), '1' error(s), and '0' warning(s) while validating dataset 'D:\\temp\\GML_Validation\\output.gml'
Translation was SUCCESSFUL with 3 warning(s) (2 feature(s) output)
