Geodatabase error (-2147219115) when using fanout
  • February 9, 2015
  • 25 views
I am reading data form an Oracle database and writing it to an ESRI File Geodatabase. It works fine until I try to use the fanout feature.  I get this error:
Geodatabase Error (-2147219115): The row contains a bad value.
FileGDB Writer: A feature could not be written
It doesn't matter whether I use the fanout at the writer level or at the feature type level, I still get the same error.  The data in the fanout field is a simple numerical version of the current date (20150209).  There are no spaces in the field. I have tried changing the geodatabase overwrite settings, the name of the geodatabase, and creating a completely blank geodatabase. So far, nothing works.
If there is another way to apend the current date to the feature type name in the writer, I would love to hear about it.
Thanks!
Best answer by janel_johnson
Well, never mind.  I started over from scratch, built a whole new workflow and geodatabases and it seems to work just fine.
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • February 9, 2015
