Extract text from string into attribute
  • Aug 3, 2015 4:13 PM UTC
  • 228 views
I have assembled table in SpatiaLite holding 30 million points of depth sounding observations originating from a number of vessels, each with a large number of files.
To keep some metadata about where each point originates from, I've kept the file path and name in an attribute called "filepath".
From the attribute "filepath", I need to extract a specific part which holds the name of the vessel. I guess it would be some regex in use here?
Example of the attribute's content:
\\folder\\VESSEL_Lola\\folder2\\file1.shp
\\folder\\VESSEL_Maria\\folder1\\file2.shp
\\folder\\VESSEL_Lily\\folder4\\file3.shp
\\folder\\VESSEL_Christine\\folder1\\file4.shp
\\folder\\VESSEL_ClaudiaMaria\\folder2\\file5.shp
\\folder\\VESSEL_Maria\\folder3\\file6.shp
and so on..
I need to extract the "VESSEL_Maria" etc. from the attribute and map to a more explanatory value in e.g. AttributeValueMapper. There is only 12 different "VESSEL_YY" categories, but a lot of different filenames of subfolders and files written in the filepath attribute.
How should I construct the Source Value parameter in AttributeValueMapper or similar?
Best answer by david_r
Hi
you can use a StringSearcher like this:
You will then get the following new attributes, e.g.:
`_matched_characters' has value `VESSEL_Maria'
`_matched_parts{0}' has value `Maria'
David
  • Aug 4, 2015 8:04 AM UTC
Hi
David
Hi David,
Thank you, works fine.
Regex is very useful but a bit hard to grasp and construct for me.
More on regex in the docs for the next readers:
http://docs.safe.com/fme/html/FME_Workbench/FME_Workbench.htm#Workbench/Regular_Expressions.htm
So far I understand it:
() - matches an empty string - look for something in a text.
\\w - looks for alphanumeric characters (letters and numbers)
* - Indicates zero or more characters.
How the backslashes in my strings are avoided, I am not sure, really.
  • Aug 4, 2015 12:32 PM UTC
Hi
Yes, regular expressions can be incredibly powerful, but they're anything but user friendly :-)
We avoid the backslashes since they're not included in the alphanumeric character class "\\w".
The paranthesis (...) is a numbered grouping operator, it matches whatever is inside it, so that you can reference it later using the "_matched_parts{}" list attribute.
If you want to learn more about regular expressions, I can recommend this tutorial: http://www.regular-expressions.info/tutorial.html
David
