Esri Licensing has problem with ArcGIS Pro in FME 2024?
davidlee
Forum|alt.badge.img+7
I am using ArcGIS Desktop 10.8.1, ArcGIS Pro 2.5 and it is working well in FME 2023+
But in FME2024 version I have problem with reading and writing geodatabase, I get the following error message:
Unable to perform any licensing related tasks. Please check your Esri ArcGIS Compatibility workspace parameter, found in Navigator -> Workspace Parameters -> Translation. This 64-bit version of FME requires ArcGIS Desktop along with 64-bit Background Geoprocessing; ArcGIS Pro; or ArcGIS Enterprise. Refer to this this article http://fme.ly/qua for more details
Failed to obtain any schemas from reader 'GEODATABASE_FILE' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
Workspace generation failed.  Parameter file was C:\Users\Acer\AppData\Local\Temp\FME_1709721529788_18364
I guess the FME2024 version has problems with ESRI licensing or maybe a change in licensing methods.
Anyone have any suggestions on this issue?
nielsgerrits
Forum|alt.badge.img+54
Have you opened ArcGIS Pro and opened a project forcing it to get a license?
How is your Esri ArcGIS Compatibility set?
  • Navigator
    • Workspace Parameters,
      • Translation
        • Esri ArcGIS Compatibility
I installed 2024.0 this morning and had no issues reading file geodatabases. I do not have ArcGIS Desktop anymore but I have ArcGIS Pro 2.9.6
davidlee
  • March 6, 2024
  • Navigator
      • Translation
I tried to set Esri ArcGIS compalibility with both parameters are Esri ArcGIS Server/ArcGIS Pro and Auto, But it Didn’t work.
I have ArcGIS Pro 2.5.0 with Advanced License, I have been using it for a long time without any problem except FME 2024 Version.
nielsgerrits
I think you are doing it right. Not sure if agspro 2.5.0 is supported but I expected it to be compatible. Next logical step is probably to submit a case at Safe.
davidlee
  • March 6, 2024
Thanks for your support!
hkingsbury
Forum|alt.badge.img+55
  • March 6, 2024
You might be out of luck, Any version of of Pro Prior to 2.6.10 appear to not be supported
https://support.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
davidlee
  • March 7, 2024
I saw it before, but i'm still using ArcGIS Pro 2.5 and it is working very well in FME 2023+
Maybe in FME 2024 it not be supported as you said.
