Dynamic DWG template
itay
Forum|alt.badge.img+17
Hi There,
I am using FME to convert data into DWG by using a predefined template. This works fine but has the limitation that I cannot dynamically create layers since they will not match with the template definitions and creating the layers in the workspace has its own disadvantages.
I cannot add all possible definitions into the template since the data and therefore the splitsing of the layers is different per conversion.
I would appreciate any ideas or other ppl experiences trying to achieve this.
Cheers,
Itay
nielsgerrits
Forum|alt.badge.img+54
I solved this by creating a template (B) from a template (A) and then create the final file based on template (B).
Also see this idea.
itay
  • March 24, 2021
Also see this idea.
Hi Niels,
Yes that is the way I was thinking of solving it too, not very efficient and possibly disruptive....that's why I was hoping for a different suggestion.
nielsgerrits
itay wrote:
Hi Niels,
An alternative I tried was to use FME to textedit a DXF template, but found more downsides and decided to go the other road.
itay
  • March 24, 2021
itay wrote:
Hi Niels,
Thx again Niels, this is even more tricky....and error prone. Appreciate you sharing this.
Seems like this is a limitation of FME that is not easy to solve.
