DXF Tagsets to DGN Tagsets
  • Oct 30, 2015 12:27 PM UTC
  • 11 replies
  • 103 views
vyaenec
I received dxf coming from Eplan Electrical schema's.
Opening the dxf in Microstation shows that Tagsets are available but not working correctly. The batch Conversion tool in Microstation works correct but it is tedious.
With FME level, line, color, text etc mapping are easy, but I can't get the tagsets to behave correctly. The Tags are all in one Tagset instead of linked to their specific Cell.
Ideas/exemples anyone?
pratap
Forum|alt.badge.img+12
  • Oct 30, 2015 1:22 PM UTC
I dont understand why I was unable to reply thru answer
Please have a look at the below link
https://knowledge.safe.com/articles/703/reading-microstation-dgn-tags-with-fme.html
vyaenec
  • Nov 3, 2015 11:47 AM UTC
e353-21.zip
I read this link, it is reading dgn,
I'm reading dxf, see attachment :-)
pratap
  • Nov 4, 2015 5:00 AM UTC
Kindly have a look with data Inspector once. If not kindly enable "autocad_attr_def_tag" in format attributes.
If still you are not able to get, kindly provide one example in the attached dxf file, I will have a look...
vyaenec
  • Nov 4, 2015 7:55 AM UTC
Hi, Tank you for your response.
I have some problems on this site with uploading data.
I thought it was uploaded but is see today that it's gone.
So, I read the link before I started, but I do dxf to dgn conversion.
The autocad_attr_def_tag was enabled.
Included is a dxf test file with entity data attached to blocks.
Thanks for looking in to it :-)
e353-21.zip
pratap
  • Nov 4, 2015 8:58 AM UTC
I have seen the data before as well but I'm not aware of names of tags you are looking for... In inspector I was able to see more attribute than normal. I think those are tags you are searching for... Connect the data to data inspector and view the attributes...
If possible do post one example with screenshot from microstation.
Pratap
vyaenec
  • Nov 6, 2015 8:19 AM UTC
This is the screen shot made with Free Bentley View.
The selected object is purple, left the element info with Tag(16) flag, Right you see the Tag content
Kind Greetings,
Chris.
pratap
  • Nov 6, 2015 1:05 PM UTC
Yes, I'm able to see these tags in FME viewer/inspector. I have added the data with Autodesk AutoCAD DWG/DXF reader and attached screenshot of result.
Which reader you are using to read the file?
Pratap
vyaenec
  • Nov 10, 2015 1:20 PM UTC
Hi Partap,
I'm using 2015.1 version...
pratap
  • Nov 12, 2015 4:57 AM UTC
I have asked "reader" not the "version" :)
I have used "Autodesk AutoCAD DWG/DXF" reader and I'm able to see the tags in inspector.
Pratap
vyaenec
  • Nov 13, 2015 12:28 PM UTC
Sorry for the misunderstanding.
I tried to convert tags to V8 dgn with "Autodesk AutoCAD DWG/DXF" and "Autodesk AutoCAD REALDWG/DXF" both show the tagsets in the inspector that's true. It's the writing technique that's troubling me.
Chris.
pratap
  • Nov 16, 2015 11:41 AM UTC
Please have a look at the below link on wrting the tags in dgn file
https://knowledge.safe.com/articles/1538/writing-m...
Pratap
