Domain Extraction from esri feature service
  • Oct 18, 2018 12:04 PM UTC
  • 160 views
hamdyahmed
Problem : i use esri feature service to read data from data provider , the problem is domains extracted with code not values . we have large amount of tables i need just a way to resolve these domains and save it in DB . may be one domain used in many tables .
is there is any idea about this issue and how to solve.
Note . i read the article Working with Geodatabase Domains: Creating A Coded Domain. it is very useful for reading from geodatabase i need same when reading from esri feature service . or just give me a workaround solution
FME version 2018.1 32bit
oscard
Forum|alt.badge.img+23
  • Oct 18, 2018 1:48 PM UTC
Could this work for you?
https://developers.arcgis.com/rest/services-reference/query-domains-feature-service-.htm
