create a json file from an excel file
  • Nov 8, 2013 3:34 PM UTC
  • 69 views
Hello,
l'm attempting to create a json file using a json existing file structure, with values coming from an excel file.
(I didn't find example with json file not in input).
My problem is that l want to fill json file only with key:value not null (as you can do in php..?) so that the key is not written in the json file.
sorry for my bad english, this an example :
if l managed to get from my excel file :
title_fr : description in fr --> title templater  "fr" : getattribute("title_fr"),
title_en : null --> "en" : getattribut("title_en")
In my title objet in the json file, l want :
title
 "fr" : "description in fr"
and not
title
 "fr" : "description in fr",
 "en" : ""
in order to have a clean json file especially when l expect to have a lot of null values depending of the case.
Hope l was enough clear for you to help me!!
thanks,
  • Nov 8, 2013 5:08 PM UTC
you could try to insert an NullAttributeRemover from the FME Store before you create your JSON output.
David
  • Nov 14, 2013 2:10 PM UTC
Thanks for your answer, but this can't work. I put my attributes in a json templater, and that way nullattributeremover can't remove it...
