check if feature class exists
  • Jul 28, 2014 6:43 PM UTC
  • 6 replies
  • 208 views
Hello,
Is there a way to check if a feature class exists in a file geodatabase . If not , throw an error .
Is this possible ?
Best answer by takashi
The Schema (Any Format) reader can be used to read feature schemas from a dataset.
The reader creates features each of which contains a schema information including feature class name ("fme_feature_type_name" attribute). You can then determine if required feature class exists.
Takashi
  • Jul 29, 2014 7:11 AM UTC
Takashi
@takashi I am pretty new to FME and am wondering how exactly I can check if a feature class exists? I was able to successfully load in the schema of the GDB and I see the attribute mentioned, but what transformer would help me best here? How can simply check if it exists?
courtney_m
Forum|alt.badge.img+23
  • Aug 8, 2017 7:11 PM UTC
You could use a Tester to test if fme_feature_type_name = <name of feature class you want to check for>
courtney_m
  • Aug 8, 2017 7:31 PM UTC
Another option is to use a Creator, AttributeManager, and PythonCaller, as shown in the following screenshot.
I have attached the same workspace for reference.
-Courtney
@courtney_m thank you, but can explain a little about what it is you put together? Why do I need to create a new fc?
courtney_m
  • Aug 11, 2017 7:11 PM UTC
Sorry for the confusion - my Python function is called CreateFeatureClass, because I modified a function from one of my existing workspaces and forgot to change the name. The script is not actually creating a new feature class - It is just checking the GDB to see if the FC already exists, and if the FC does not exist, it prints "Error" in the log window.
