Change danish social security number
  • Jul 21, 2016 8:58 AM UTC
  • 78 views
The danish social security number are build up like (ddmmyy-xxxx) where xxxx is a unique code.
I have a dataset from a xlsx-file, where the danish social security number are like (ddmmyyxxxx) AND if the date startes wtih 01, 02 ect, then it cut the zero of.
I need to make FME read the xlsx-file and change the danish social security number to this format (010180-1234) and write it to my PostGIS-DB.
I hope someone can help me with that.
Best regards,
Jacob Arpe
Kalundborg Municipalty
Forum|alt.badge.img+63
Here's what I did:
  1. StringLengthCalculator to calculate the length of the number. If it's 9 characters it's missing a leading 0. Those features get routed through an AttributeCreator that adds the 0
  2. AttributeSplitter to split the first 6 characters (the ddmmyy) off from the rest, this results in a list with 2 elements (_list{0} = '010180' and _list{1} = '1234')
  3. AttributeCreator to create a new attribute which is _list{0}, a dash and then _list{1}
Hope this helps. You may want to consider adding some extra error checking, e.g. in the TestFilter to see if there's any numbers which are not 9 or 10 characters in length.
Forum|alt.badge.img+54
  • Jul 21, 2016 10:23 AM UTC
If it's a fixed length and it's always the leading zeros you are missing you can simply use a string padder to add 0 to the beginning of the field to make it up to the required length. Once it is the required length you can split and add the - using attribute manager/attributecreator
  • Jul 22, 2016 10:57 AM UTC
Here's what I did:
It worked perfect. Some small modifications, but in general the workflow I need. Thanks.
  • Jul 22, 2016 10:59 AM UTC
Didn't try this one, but StingPadder is also new to me, but a great tool. Can use the in other workflows. Thanks.
