Attribute type message when opening 2016.1 Workspace in 2017.0
tim_wood
Forum|alt.badge.img+8
I've just opened one of my 2016.1 Workspaces that reads a ShapeFile in 2017.0 and some ArcSDE layers and writes to 2 File Geodatabases (FGDBs). I got the following message in the translation log:
Attribute type 'fme_char' not found in ATTR_TYPE_MAP. Trying 'fme_int8'
Attribute type 'fme_int8' not found in ATTR_TYPE_MAP. Trying 'fme_int16'
I've still got 2016.1 installed so I'll run the Workspace in that, but I'd appreciate any explanations of what this means. I'll try re-creating the Readers and Writes in 2017.0 when I get a chance.
erik_jan
Forum|alt.badge.img+22
  • April 10, 2017
Have you tried re-creating the File geodatabase writer in FME 2017?
I have a PR with Safe. Some things got broken in the File geodatabase API.
Might be related.
erik_jan
  • April 10, 2017
Might be related.
And I should have read the last lines of your question a bit more carefully.
Let us know if re-creating worked.
tim_wood
  • April 10, 2017
Might be related.
Thanks. However the Writers in my Workspace are File Geodatabase (ArcObjects) so maybe not the same problem...
tim_wood
  • June 12, 2017
The same thing happens opening a 2016.1 Workspace in 2017.0.1.1 (32-bit and 64-bit). Does @erik_jan or anyone else have an update on this?
My Workspace does 2 things:
1) Reads a ShapeFile, processes it and writes out various File Geodatabase layers using the File Geodatabase ArcObjects Writer.
2) Reads several ArcSDE layers using the ArcSDE Geodb Reader and writes them to a backup File Geodatabase, again using the ArcObjects Writer.
Most fields are data type Char, with some Double and a few Integer and Smallint.
