3D Shapefile with 3DForcer?
  • Jan 22, 2020 10:50 AM UTC
  • 192 views
alfons
Forum|alt.badge.img+7
Hello,
i'm pretty sure it's a simple problem, but somehow i'm not able to write a 3D shapefile. Every time I look at the feature information in the Data Inspector, I get "2D" as the dimension. But I need "3D" as dimension.
As a test, I have written the script below. After I have created a "test point", I create an attribute with a height, which I write into the Z-value using the 3DForcer. When exporting I want to write a 3D shapefile, but I have some kind of error and I can't see the forest in front of the trees anymore.
Thanks a lot for the help
Best answer by alfons
I found the problem with the help of the provided script by oscard. When I used the script, I received a message that the script was saved with a newer version - good to know. After checking the "new" result, I received a 2D shapefile again. So I checked FME of a newer version - I worked with FME 2019.2.2.0 b19813 20191202 and the updater found a newer version FME 2019.2.2.0 b19817 20200103, which I have now installed. During the installation I checked the changelog and found the following fix:
FME 2019.2.2.0 b19815 20191211
Shapefile: Fixed incorrect output geometry dimension when using pre-set
shape types [FMEENGINE-62406] C150378
Sounds exactly like my problem. After updating my FME and testing my original workspace, I got the result I expected - the dimension is 3D.
So thank you all for your help.
oscard
Forum|alt.badge.img+23
  • Jan 22, 2020 11:08 AM UTC
I can't download your workspace.
But I have built something similar and is working fine
shape3d.fmw
Forum|alt.badge.img+63
Did you set the output dimension in the feature type properties?
sigtill
Forum|alt.badge.img+25
  • Jan 22, 2020 12:04 PM UTC
1. Please upload the workspace again - it is not possible to download
2. Show a screenshot of the feature from the Inspector called CoordinateExtractor_Output
alfons
  • Jan 22, 2020 12:07 PM UTC
