How to Pass AttributeCreator Values into PythonCaller Custom Array
  • Jun 13, 2023 11:49 PM UTC
  • 5 replies
  • 145 views
fmelearner
Forum|alt.badge.img+3
Having a Workspace like this
imageand the AttributeCreator like
imageCan you please let me know how I can pass the AttributeCreator Values into the PythonCaller. Like following pseudo code to loop in the attributes from the AttributeCreator
    def input(self, feature):
      for attr in .pythoncreator.getAttribute:
            print(attr )
        self.pyoutput(feature)
itsmatt
Forum|alt.badge.img+48
  • Jun 14, 2023 5:51 AM UTC
You can use "feature.getAllAttributeNames()" to get a list of all the attribute names.
e.g., attlist=feature.getAllAttributeNames()
You can then use feature.getAttribute() in a loop like:
  for att in attlist:
          att_name = att
att_value = feature.getAttribute(att)
print(att_name)
print(att_value)
  • Jun 14, 2023 7:00 AM UTC
@virtualcitymatt​ is right, here's a code sample with indentation:
for attr_name in feature.getAllAttributeNames():
    attr_value = feature.getAttribute(attr_name)
    print('Attribute {} = {}'.format(attr_name, attr_value))
 You'll certainly also want to have a look at the fmeobjects documentation, found here: https://docs.safe.com/fme/html/fmepython/api/fmeobjects/_feature/fmeobjects.FMEFeature.html
fmelearner
  • Jun 14, 2023 1:47 PM UTC
Thanks for reply David but this is returning ALL Attributes in the workflow which I do not need them!
Attribute 1 = parks
Attribute 2 = swers
Attribute 3 = streets
Attribute 4 = schools
Attribute _creation_instance = 0
Attribute fme_feature_type = Creator
Attribute fme_geometry = fme_undefined
Attribute fme_type = fme_no_geom
and what I need is just this list from AttributeCreator
Attribute 1 = parks
Attribute 2 = swers
I checked the API but couldn't find out any parameter for fmeobjects.FMEFeature.getAllAttributeNames to limit this to only my specific AttributeCreator
Thanks
  • Jun 14, 2023 3:28 PM UTC
Attribute 1 = parks
Attribute 2 = swers
Attribute 1 = parks
Attribute 2 = swers
Thanks
Indeed, fmeobjects does not keep track of which attribute was added or modified at which point in the workspace.
itsmatt
  • Jun 15, 2023 8:14 AM UTC
Attribute 1 = parks
Attribute 2 = swers
Attribute 1 = parks
Attribute 2 = swers
Thanks
You can try and work around it by adding a prefix to the attributes you want to use. You can then remove this prefix in the python code​.
