CRON Expressions - best way to learn?
  • Feb 9, 2024 10:24 PM UTC
  • 772 views
vxn43
Forum|alt.badge.img+20
Can someone provide a link/info on where I can learn more about CRON Expressions? I know what they are used for and why but have never actually used them before. Thank you.
Best answer by danilo_fme
Hello @timh
I started to learn using these links:
Doc - FME Flow
Generator CRON Expression
FME Flow - CRON
Thanks in Advance,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Feb 11, 2024 1:47 PM UTC
Hello @timh
Doc - FME Flow
FME Flow - CRON
Thanks in Advance,
Danilo
hkingsbury
Forum|alt.badge.img+73
  • Feb 11, 2024 6:49 PM UTC
Another good, albeit possibly controversial place to learn, is ChatGPT
Heres an example: https://chat.openai.com/share/23ddc24a-6ad2-4d90-a778-4c8bdd7d598c
One thing to note in general about FME and Chron, is FME uses the Quartz scheduler, there are a couple of different syntaxes for Chron so make sure any references you’re following work in Quartz.
They also have a tutorial page - http://www.quartz-scheduler.org/documentation/quartz-2.3.0/tutorials/crontrigger.html
danilo_fme
  • Feb 11, 2024 10:40 PM UTC
Hi @hkingsbury thanks for endorsing the answer!
