Using one AttributeRounder for different accuracies
  • July 10, 2025
  • 33 views
stadimarmiladi
Forum|alt.badge.img+8
Hello all,
is it possible to use one AttributeRounder to round different attributes to different accuracies?
Let’s assume i have two attributes, A and B. I want to round A to 2 decimal places, whereas i want to round B to three decimal places. Is this possible with one AttributeRounder or do I need to use the AttributeManager.
Cheers!
Best answer by max_h
As far as I can tell you would need two rounders for this case as it is not possible with conditional values (someone correct me if I am wrong please).
So easiest case would be as you suggested attribute manager with:
@Evaluate(@round(@Value(A),2))
@Evaluate(@round(@Value(B),3))
max_h
Forum|alt.badge.img+16
  • July 10, 2025
