Automations with Data Download Service
  • February 18, 2020
  • 187 views
I have another FME Server query!
I have successfully uploaded an FME workbench to FME Server 2019.1 with a Data Download Service. When I run the workspace in FME Server the Data Download Service works fine.
I would also like the Data Download Service to work with a scheduled job which I have set up using Automations. However whenever this scheduled job runs, the Data Download Service does not work and the files are output to the shared directory rather than a zip file to download.
Is it actually possible for the Data Download Service to work in a scheduled Automation? I thought maybe I could add the hyperlink to the zip file to an email, but I can't work out how to do that.
Thanks
Hi @aquamarine,
This kind of question has already been asked a few times (although not specific to automations):
https://knowledge.safe.com/questions/59695/scheduled-job-data-download-not-included-in-email.html
https://knowledge.safe.com/questions/65259/retrieve-data-download-url.html
My recommendations would be:
1. Send it as an attachment if you can
2. The Data Download doc explains how you can set up the Data Download to run as a schedule:
https://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/service_datadownload.htm
For this, as you'd be making a HTTP Request and telling it to run later, you could do this with a HTTP Action in automations. You'd then need to set up the emailing (which might be legacy notifications + topics)
3. Have a workspace that makes a HTTP request to the Data Download service and get the data url from the response and send the email within that workspace. In FME Server 2020+ you'd be able to use the automations writer and pass this value out to the Email action.
