Using filecopy to copy a file in a user parameter specified folder
  • Jun 16, 2020 3:11 PM UTC
  • 62 views
mackenziebudda
Participant
Forum|alt.badge.img+5
My current workspace has a prompt for the user to specify a folder that will be copied and uploaded to a few different places. One thing I would also like it to do is copy a .kml file inside this folder to another location. Every time the workspace will be run the user will be selecting a different folder but the .kml inside each folder will be going to the same spot as every other .kml.
Here is my current filecopy writer where $(job_folder) is the user specified folder. I try to set the source dataset as the user parameter but to only "filter" through any .kml's inside:
Is this possible?
Thanks!
mackenziebudda
Participant
Just thought I would post an update that it was actually working and that I actually just specified the wrong destination folder....my bad
HOWEVER it's not renaming the file. In the filecopy documentation it says the filename can't be changed if the source dataset is a folder. Any suggestions for getting around this?
