Transfer attributes from neighbouring text features
  • Oct 25, 2017 2:28 PM UTC
  • 5 replies
  • 96 views
whkarto
Forum|alt.badge.img+14
I'm facing some troubles to figure out how to transfer some attributes that are present on some text lines to subsequent text line features.
See below a screenshot of my data situation
Whenever -99 occurs a new dataset begins. The next two number are static values and then various measured records will occur. What I'm trying to achieve is, to pass on the two static values to every record ot the dataset. As soon as a new dataset (-99) begins the mechanism should reset and now use use the most recent values for inheriting.
Find attached my current workspace together with a small sample dataset.
Thanks for your help!
Best answer by takashi
Hi @whkarto, if I understood the requirement correctly, this workflow would be a solution.
Forum|alt.badge.img+54
  • Oct 25, 2017 2:33 PM UTC
Take a look at the adjacent attribute handling capablilities under advanced attribute value handling in the attribute creator. This will allow you to set a value of an attribute based on a value in the previous feature
inherit-attributes.fmw
  • Oct 25, 2017 2:43 PM UTC
As an aside, if your data is as per your sample, it's a lot easier if you read the text file as column aligned text
  • Oct 25, 2017 4:21 PM UTC
  • Oct 25, 2017 4:23 PM UTC
global-variables.fmwt (FME 2017.1)
whkarto
  • Oct 25, 2017 6:50 PM UTC
@takashi Thanks a lot! Once again you did it! The approach with variables ist really clever, although you'll have to make sure that data schema is strictly obeyed. But that could be done in advance.
