DocumentPDFStyler: URL in a table
  • Jul 18, 2025 6:31 PM UTC
  • 190 views
carlm
Forum|alt.badge.img+23
I’m trying to put an URL in a table using the new DocumentPDFStyler and I can’t make it work.
One of my issue is that the URL breaks because it doesn’t fit in the table box, also it doesn’t show up as an url.
I tested many things to make it work: Image Link, add the pdf_url attribute (doesn’t work because this is the documentpdf writer),  put quotes around it.
I’m trying to make this work without having to use the wkhtmltopdf 😅
Best answer by saraatsafe
Hi ​@carlm, I’m not sure what your table or PDF setup looks like, but one way you can add a URL into a table is by turning the link into an attribute first. Please see the attached workspace for an example-- I created an attribute for the URL text and the URL itself, and then added them to the DocumentPDFStyler via [@Value(text)](@Value(link)) as the column value. I hope this helps!
saraatsafe
Forum|alt.badge.img+13
  • Jul 21, 2025 6:53 PM UTC
carlm
  • Jul 21, 2025 7:17 PM UTC
Thanks it works, this information should be added in the documentation (how to reference an URL).
saraatsafe
  • Jul 21, 2025 8:55 PM UTC
Hi ​@carlm, thank you for the feedback! I’ve submitted a ticket to the publications team for this.
saraatsafe
  • Jul 25, 2025 3:59 PM UTC
Update: the documentation for the DocumentPDFStyler has been updated to include a section on inserting links.
