How share an Automation app without requiring to authenticate
  • Jul 16, 2025 9:08 AM UTC
  • 179 views
joy
Forum|alt.badge.img+15
Hello everyone,
I have a short question. How can I share an automation app so that an user doesn't need to  authenticate. himself/herself?
I am able to share workspace apps with users by disabling the Require Authentication button, but I can't find something like that for an automation app.
I also looked at manage token and enabled some options with Automation, but still the autonmation app does require an user to authenticate himself/herself.
Best answer by johannafalk1
as far as I am aware this is a set restriction and there is no way to make an Automation App itself accessible without authentication.
However, you can possibly overcome this with a little workaround. Create a workspace app, that does not require authentication and then trigger from there the desired automation. For example: You can trigger a “topic” in the Workspace behind the workspace app, the topic is then further triggering the automation. (A topic can be set as a trigger for the automation).
Hope this helps.
johannafalk1
Forum|alt.badge.img+20
  • Jul 16, 2025 1:13 PM UTC
Hope this helps.
joy
  • Jul 17, 2025 7:49 AM UTC
Hello Johanna,
To me, it doesn’t seem logical that you don't need authentication for a workspace app, but does for an automation app. I upvoted this idea Automation Apps without authentification | Community
Thanks for the advice — I just have a few questions before getting started.
  1. How do I trigger from a workspace app to an automation? Probably I have to create a workspace that does that?
  2. In my current automation app, I have a manual trigger for geometry and an email. If I’m going to use the workspace app as the trigger, I still need the user to provide the geometry parameter. Is it possible to do that when using a workspace in combination with an automation?
  3. If I understand your message correctly, I need to trigger the workspace app, but I also need the FME Topic to be notified within the automation itself, is that right?
johannafalk1
  • Jul 17, 2025 12:27 PM UTC
I would try to do it like this then:
  1. Create a new topic only for this purpose.
  2. Then you create a workspace where you have the required user parameters → Geometry and email. You then transform this information from the user parameters into a json and send it to the newly created topic through the FMEFlowNotifier.
  3. Then you will have your desired automation, that has a “FME Flow Topic” as a trigger. You can configure custom output attributes that will contain the trigger content (Geometry and Email). And that you can further process in your automation as you planned it.
    1. See here accessing topic messages: FME Flow Topic
Hope this is somehow helpful.
Here is a tutorial, where topics and custom attributes in automations are explained well: Working with Automation Parameters and Custom Attributes in an Automation | User and Global Keys – FME Support Center
joy
  • Jul 21, 2025 9:48 AM UTC
Hello ​@johannafalk1 ,
I managed to create a Workspace app that triggers the automation and is publicly available.Thank you very much for providing the steps!
