String Value to integer in Python
Hi. I have a table with an attribute with string values such as "39.1234". I'm trying to extract the integer of this to a new attribute using Python. So something like this
import fme
import fmeobjects
def processFeature2(feature):
vStartMiles = feature.getAttribute('Start_Mileage')
vStartMiles2 = int(vStartMiles)
feature.setAttribute("Start_Miles", vStartMiles2)
However, this code gives the following error and i've tried various other options without success. Any ideas how to to extract the integer from a string with Python? Thanks
Best answer by jeroenstiers
Hi ericarmitage,
As david_r already mentioned, it is important to use the round function when converting from a float towards an integer. Below I also implemented a try-except block to show a warning in the log if the conversion fails.
import fme
import fmeobjects
logger = fmeobjects.FMELogFile()
# Template Function interface:
def convertToInteger(feature):
    string = feature.getAttribute('string')
    try:
        integer = float(string)
        integer = round(integer)
        integer = int(integer)
        feature.setAttribute('integer', integer)
    except:
        logger.logMessageString('The following string couldn\'t be converted towards an integer: %s.' % (string), fmeobjects.FME_WARN)
this is the error
Python Exception <ValueError>: invalid literal for int() with base 10: ''
Error encountered while calling function `processFeature2'
PythonFactory failed to process feature
Bridge failed to output feature on tag `PYOUTPUT'
  • January 19, 2016
Hi
Looks like Start_Mileage can sometimes be an empty string, you will have to handle that to avoid or ignore the ValueError exception. Something like:
try:
except:
    pass
Notice the try/except-block that ignores any potential errors when casting vStartMiles into an integer. You could easily adapt the above to treat these special cases as you see fit.
Now, having said that, I'm not quite sure what you're trying to accomplish with the above. FME is normally pretty good at casting its attributes to integers when necessary, without user intervention.
David
Thanks David. I've filtered out the features with empty strings before the Python caller and it works ok. However, the int function doesn't seem to work on a decimal string but vStartMiles2 = int(float(vStartMiles)) does
Eric
  • January 19, 2016
Eric
That is correct, you cannot cast a string looking like a float as an integer.
Be aware, however, that int(2.9) = 2 and not 3! Use round(float(vStartMiles) to get the value 3.
David
Forum|alt.badge.img+7
  • January 20, 2016
Hi ericarmitage,
import fme
import fmeobjects
    try:
    except:
