Return largest parameter value in scripted parameter (possible bug)
  • Apr 1, 2024 1:11 PM UTC
  • 112 views
dustin
Forum|alt.badge.img+36
 I have 3 published parameters where the user inputs values for buffers. All three were created as Numeric parameters, with numeric precision set to Integer. I would like to extract the largest buffer value in a python scripted parameter. This is the code I’m using in FME 2023 (build 23332)
buffer_list = [FME_MacroValues['BUFFER1'],FME_MacroValues['BUFFER2'],FME_MacroValues['BUFFER3']]
buffer_list.sort(reverse = True)
return buffer_list[0]
What I’ve discovered is that if the 3 buffers are the same number of digits, the script will return the correct value. If the number of digits is different, it will not. Some examples:
10, 40, 50 = 50 (correct)
120, 60, 70 = 70 (incorrect)
120, 180, 70 = 70 (incorrect)
120, 200, 300 = 300 (correct)
It doesn’t matter which order the values are input, nor does it matter how the parameters are sorted in the parameter list.
Is this a bug, or am I missing something?
Best answer by debbiatsafe
Hello @dustin,
Parameter values are always fetched as strings. You will need to cast the parameter values to integers if you need to get the numerical max.
return max(int(FME_MacroValues['BUFFER1']),int(FME_MacroValues['BUFFER2']),int(FME_MacroValues['BUFFER3']))
Note the original behaviour noted is not a behaviour specific to FME. I believe strings are sorted based on code-point value of the first character.
debbiatsafe
Forum|alt.badge.img+24
  • Apr 2, 2024 12:53 AM UTC
Hello @dustin,
dustin
  • Apr 2, 2024 9:36 AM UTC
Hello @dustin,
This worked great, thank you.
