Need an idea for a new useful custom transformer or format!
  • Aug 23, 2017 8:24 AM UTC
  • 40 replies
  • 212 views
Show first post
mark2atsafe
Forum|alt.badge.img+59
I've been thinking about doing a custom transformer to implement my PedanticSorter idea but haven't had time.
https://knowledge.safe.com/idea/41576/sorter-options-for-handling-null-missing-empty-str.html
Well @tim_wood and @sander_s - I'm not sure if it's the most efficient, but it seems to work OK. Have a go and let me know what you think. You can make the non-values appear at the top/bottom of the pile, and you can choose the order of Null/Missing/Empty too.
https://hub.safe.com/transformers/controllednullsorter
jdh
Forum|alt.badge.img+41
  • Aug 24, 2017 6:53 PM UTC
@jdh: I think I'm going with the ListAppender for now! As usual, the GUI is the hardest nut to crack... In order to decide how I'm going to build it, could you tell me if the transformer should be able to deal with nested lists as well? And if that is the case, should it append attributes to all "sublists" or only a selected one?
For instance, when appending to parent{}.child{}.value, should it append new child.values for every parent (which seems a bit odd to me)? Or should you be able to select parent{n}.child{}.value, where n is a selected parent list node, so that new child.values are appended for a specific parent?
The latter would make more sense, but GUI-wise, it's a nightmare. I also had to create a hacky solution for my ListKeyValuePairExtractor (that also supports nested lists), so it would be cleaner to only support non-nested lists.
The version I wrote (which unfortunately cannot be shared) handles complex lists(_list{}.a) but not nested lists (_list{}.x{}), for pretty much the GUI reason.
jdh
  • Aug 24, 2017 6:59 PM UTC
Hi, @sander_s. If there are any of these ideas that you don't want to work on, let me know - I have had some free time lately as well, and am looking for FME brain-food. :-)
Go with the orthogonal generalization :). It's probably the most complex, but also the most useful.
geosander
Forum|alt.badge.img+7
  • Aug 24, 2017 7:19 PM UTC
Nice work! Next version should support multiple attribute sorting though ;)
By the way, I noticed this when I first opened the parameters dialog:
Probably needs a little clean up.
Oh and nothing important, but in the bookmark descriptions it says "...Appendage" but in the private parameters it says "...Suffix".
But other than that, good stuff!
mark2atsafe
Yes, multiple attribute sorting presents a bit of a challenge. Actually a lot of a challenge. The Sorter only accepts one attribute at a time, so I'd need to know in advance how many attributes to sort by. Or switch to python, which I'm very loathe to do.
The "unusedCfg" part of the label is a mystery. I didn't add that. Filed it with the developers. And ParkName is just the default I used in my test data.
Ha! I used "appendage" at first rather than suffix, until I realized that gave me not just NullAppendage, but MissingAppendage! Missed changing that part though.
geosander
  • Aug 24, 2017 8:41 PM UTC
Alright, I'll have it support nested lists then, since I already wrote the code for that in the ListKeyValuePairExtractor.
Meanwhile, I posted an idea for a new/enhanced GUI type, so please vote! ;)
geosander
  • Aug 24, 2017 8:44 PM UTC
A transformer that sorts missing appendages, wow...! :D
pratap
Forum|alt.badge.img+12
  • Aug 25, 2017 4:46 AM UTC
Hi @courtney_m, I would suggest to kindly post your requirement. Out of the suggestions posted orthogonal generation seems to be interesting for me to try, so I'm trying it. I don't know how much time it will take :). If your requirement is taking less time then normally I can change the focus and complete.
Hope @sander_s don't have objection since he is the owner of the post :)
geosander
  • Aug 25, 2017 8:23 AM UTC
Sure, no problem @pratap! I might also give it a go, but not sure how long it's going to take me either. We could turn it into a contest! ;)
tim_wood
Forum|alt.badge.img+8
  • Aug 25, 2017 9:18 AM UTC
Thanks :-) I'll try and dig out the data I was using at the time this came up and give it a go. I prefer my name for the transformer though ;-)
jdh
  • Aug 25, 2017 1:38 PM UTC
I don't have time, which is why I sent the papers to Marc originally, but if multiple people are going to give it a go, why don't you each pick a different paper to try and implement.
rylanatsafe
Forum|alt.badge.img+14
A visual compare and diff between two workspaces. Which transformers, readers and writers are added, modified or deleted. See: https://knowledge.safe.com/idea/51439/visual-compare-two-workspaces.html
Ah, yes! I was working on something myself in off hours.. I used the FMW Reader (in FeatureReader) and way too many FeatureMergers – this was a very messy approach so I simplified it to just checking transformers.
It is not fully tested but might be useful,.. so I have attached!
@sander_s
workspacechangedetector.fmw
jdh
  • Aug 28, 2017 3:37 PM UTC
@sander_s
I feel your pain, when I was toying with this back in february, I ended up with 6 feature mergers, and that was just comparing readers and writers and their featuretypes.
mygis
  • Aug 29, 2017 9:32 AM UTC
Hey, I like being special ;)
All Aquariuses are !
geosander
  • Sep 5, 2017 2:33 PM UTC
FYI: I finished and uploaded the ListAppender today. Check it out on the FME Hub!
