Merge features by attribute that contains string from target attribute
  • Jan 27, 2017 11:21 AM UTC
  • 527 views
edgarrunnman
I want to merge features by attribute that contains string from target attribute.
FeatureMerger does job done but only in case where attribute(req) = attribute(sup). In my case i want to expression to loke like this attribute(req) CONTAINS attribute(sup).
  • Jan 27, 2017 11:39 AM UTC
Have a look at this similar post:
https://knowledge.safe.com/questions/38771/can-i-use-a-feature-merger-to-merge-partial-names.html
Basically just expand the wildcard to something like
select *
from table_a join table_b on '%' || table_a.id || '%' like '%' || table_b.id || '%'
Just be aware that matching on substrings is relatively slow.
edgarrunnman
select *
Impressive replay time :) InlineQuerier did the job!!!
Thank You
Forum|alt.badge.img+7
Another question that might be solved by implementing string functions and regex!
https://knowledge.safe.com/idea/38779/allow-regex-to-perform-matching-in-featuremerger.html
jaywood
Participant
  • Participant
  • Jun 20, 2019 2:01 AM UTC
I had similar requirement. Solved using Inlinequerier
Sample below joins table SAP To LOC, where SAP.MatchedPlatform is a sub string in LOC.LOC_OTH_NAME_MATCH
creates
SELECT * FROM SAP LEFT JOIN LOC ON INSTR(LOC.LOC_OTH_NAME_MATCH, SAP.MatchedPlatform) > 0
Hope this helps
