How to replace multiple strings in single attribute?
  • Jan 7, 2020 7:43 AM UTC
  • 6 replies
  • 181 views
I have attribute, that contains mostly 3 street names (there are 1 to 4 street names per attribute).
Street names are in finnish, but I would need them also in swedish. I have csv-file that contains street names in finnish and swedish
Single street name would be easily changed with AttributeValueMapper, but how can I change 3 in same attribute?
for example "Mikael Lybeckin tie (Kasavuorentie-Bredantie)" => "Mikael Lybecks vägen (Kasabergsvägen-Bredavägen)"
This solution is quite close ebygomm Python script
  • Jan 7, 2020 8:03 AM UTC
Try something like this in a PythonCaller (assuming Python 3):
import fmeobjects
import csv
class multi_string_replace(object):
    def __init__(self):
        with open(r'C:\my_streets\street_mapping.csv') as csvfile:
            self.street_mappings = dict(csv.reader(csvfile, delimiter=';'))
    def input(self, feature):
        street_name = feature.getAttribute('street_name_attribute')
        if street_name:
            for search_name, replace_name in self.street_mappings.items():
                street_name = street_name.replace(search_name, replace_name)
            feature.setAttribute('street_name_attribute', street_name)
        self.pyoutput(feature)
This will read the file 'C:\my_streets\street_mapping.csv' once at startup, caching all the search-replace pairs in a Python dictionary. For each feature that enters the PythonCaller, the attribute street_name_attribute will be processed to replace all the names found in the street name attribute with the corresponding values from the csv.
  • Jan 7, 2020 8:50 AM UTC
import fmeobjects
import csv
    def __init__(self):
        if street_name:
Thank you @david_r! I am using Python 3.7.
I changed csv-filename and attribute name, but I get error and I don't know why
  • Jan 7, 2020 9:11 AM UTC
The code above was untested and contained two errors, I've fixed them now. Hopefully it works as promised.
becchr
Forum|alt.badge.img+35
  • Jan 7, 2020 9:12 AM UTC
hi @bazooka, i had this error before with using wrong indentations... Everything looked nice, but i used a mix of spaces and tabs: not OK.... Under options you can enable 'Show spaces/tabs' (and line numbers too by the way).
Maybe worth checking this out first?
  • Jan 7, 2020 9:16 AM UTC
I had forgotten a closing parenthesis on line 8, unfortunately... Fixed now.
But yes indeed, indentations are a common issue when copy/pasting code, in particular from forums like these.
  • Jan 7, 2020 10:44 AM UTC
Now code works! Thanks again!
