FME ETL Tool Log location no longer a Workspace Parameter
jon
Forum|alt.badge.img+5
I've copied my workbench into a new ArcToolbox "FME ETL Tool" and now the Log File Workspace Parameter is no longer available.  The log files are being saved, but there doesn't seem to be a way to change the location they are saved.
To find the log, I went into ArcCatalog Options --> FME --> View Logs... which opens up the following location:
C:\\Users\\<user name>\\AppData\\Local\\Safe Software\\Interoperability\\logs
Is there a way to change the location of where these logs are saved in a FME ETL Tool?
