ERROR |BADNEWS ??
  • September 12, 2013
  • 392 views
farfar
Forum|alt.badge.img+11
Hi all,
if i launch a workbench, it executes no problem but i see this error into log file when i checked "Log Debugging information" from Tools==> FME Options==> Runtime=>Log file Default".
ERROR |BADNEWS: File C:\\Program Files\\FME\\metafile\\MULTI_WRITER.fmf could not be opened (tabrdr.cpp:997)
ERROR |BADNEWS: File C:\\Program Files\\FME\\metafile\\PythonFactory.fmf could not be opened (tabrdr.cpp:997)
ERROR |BADNEWS: File C:\\Program Files\\FME\\metafile\\QueryFactory.fmf could not be opened (tabrdr.cpp:997)
What that means this error?
Thanks an advance.
FarFar
if your workspace executes correctly, I would not pay any attention to these messages. Safe also recommends that you do not turn on this option unless you're working on a specific issue with them.
David
farfar
Ok. Thanks.
FarFar
  • March 20, 2014
But surely if::
is not on my hard drive this would be somewhat of an issue?
I get this eror later on in my log:
BADNEWS: No MULTI_WRITER dataset name was specified (couldn't find a value for `MULTI_WRITER_DATASET') (writrimp.cpp:549)
Any ideas?
I have been going around in circles for a week with this.
thanks
Russ
Go to tools FME Options then on Runtime untick Log debugging information
You only need this if you're working on a specific issue with Safe.
Darren
