Create multiple features from list within an attribute
  • Oct 16, 2018 7:30 PM UTC
  • 348 views
I have a column (route_num) with a list of route numbers. How can I extract each route number as it's own feature and all other attributes as copies. See below
To:
Best answer by hollyatsafe
Hi @mariofederis,
First use an Attribute Splitter to generate a list of the values in ROUTE_NUM, then use the ListExploder to explode each list member into its own feature with the accumulation mode set to 'Merge List Attributes' and Conflict Resolution to 'Use List Attribute Values'.
Here is an example workspace: listtofeatures.fmw
  • Oct 16, 2018 7:51 PM UTC
Hi @mariofederis,
Hi @mariofederis,
Thanks Holly! It worked. Thought I had to do a looper of some sort.
  • Sep 30, 2020 4:32 AM UTC
Hi @mariofederis,
Hi @hollyatsafe​ May I have your example workspace for testing, great thanks!
Hi @heya​ ,
Thanks for letting us know the attachment link was broken. I've updated the original answer post so you should be able to access it now.
