there was an error retrieving the jobs in fmeserver 2017
  • May 11, 2023 2:43 AM UTC
  • 75 views
itsmatt
Forum|alt.badge.img+48
  • May 11, 2023 7:34 AM UTC
The logs would suggest that the Database service got shut down. Are you on a distributed system? You will need to restart the Database Service.
I suggest you try to restart FME Server and see if that solves the problem.
Thank you, after restarting, I still can't load the jobs page, and the developer page reports an error message such as an attachment, I don't know if I need to configure it in the domain name environment, and how to configure it。
itsmatt
  • May 11, 2023 9:55 AM UTC
Maybe have a run through of this: https://community.safe.com/s/article/fme-server-troubleshooting-guide
Without knowing specifics of your environment it's a bit hard to understand what the issue is
