Can FME-Workbench be used in a GUI for CentOS7
  • Aug 16, 2018 4:55 PM UTC
  • 5 replies
  • 87 views
I've got FME workbench installed and licensed on a CentOS7 machine an Amazon EC2. I've successfully run models through command line, but I would ideally like to have the actual FME GUI. I followed these instructions to install a the gnome gui and connecting through VNC https://www.digitalocean.com/community/tutorials/how-to-install-and-configure-vnc-remote-access-for-the-gnome-desktop-on-centos-7#step-8-%E2%80%94-securing-vnc-sessions-through-ssh-tunneling
When I click on the FME workbench application in the gui it crashes when it tries to load the main window.
Do I just need to use something other than gnome?
Best answer by philiptivel
Andrea, based on that error I did a yum remove dracut-fips and now the FME Workbench UI appears to be working!!!
andreaatsafe
Forum|alt.badge.img+17
Hi @philiptivel,
Could you try running the following command to see if it works or provides more information:
/opt/fme-desktop-2018/fmeworkbench fmetest.fmw
Andrea, I get this error when I run that command:
[maintuser@ip-172-31-2-18 data]$ /opt/fme-desktop-2018/fmeworkbench fmetest.fmw bf_skey.c(69): OpenSSL internal error, assertion failed: Cipher BLOWFISH forbidden in FIPS mode! Aborted (core dumped)
  • Aug 16, 2018 5:46 PM UTC
andreaatsafe
That's great to hear! Thank you for the updates!
ravenkopelman
Thanks for the update @philiptivel - we'll consider reducing our use of Blowfish so that FIPS enforcement doesn't have to be disabled on the system.
