Workbench parameters best practice when using c# and REST interface
  • Sep 21, 2020 1:06 PM UTC
  • 118 views
r_huesken
Forum|alt.badge.img+5
I need to pass quite a few parameters (10+) to my workbenches running on FME server. The jobs are started though a call to the FME SERVER rest API, from a c# application.
I'm considering 2 options:
1) specify each parameter individually, which requires some additional coding in c# when calling the workspace.
2) specify a single JSON parameter, which combines the values of all parameters. Passing parameters to the workbench will be more generic, since the set of parameters may be organised in a class and (de)serialized when required.
What would be the pros and cons of both methods?
anhphuongt
Hi r_huesken,
What I usually do is getting the list of all the parameters for each workspace and fill these parameters individually, then run the workspace.
I think it is better that way because you can run preexisting workspace without modifications . Also if someone want to run the workspace directly on FME Server without using your C# application it would be simpler for them then trying to construct a JSON manually to run the workspace.
r_huesken
  • Sep 22, 2020 7:13 AM UTC
Hi r_huesken,
Thanks, useful suggestion.
