Why does a directory and pathname reader throw a write permission error?
  • Aug 17, 2026 7:45 PM UTC
  • 134 views
gisbradokla
Forum|alt.badge.img+27
FME Flow using a directory and pathname reader transformer. it has run in this folder before (different fme version) and not had this error.
PATH Reader: Error reading path '\\Tx-mio-miso1\mi-shared2\SUR\MoDC_TXAS_NRGY\COUNT_FLEET_\ASBUILT\WORKING' with error message: 'The media is write protected.'
Why does a reader transformer need write access?
It doesn’t even get to the writer and fails
hkingsbury
Forum|alt.badge.img+73
  • Aug 23, 2026 7:35 PM UTC
I’d be interested to understand this too. I’ve noticed some other formats (SQLite being on of them) will often lock the entire database for just a read
veronikaatsafe
Forum|alt.badge.img+13
I saw you open a support case regarding this issue and that this may have been related to changes with your network shares. I'm also sharing the idea you created here for visibility:
https://community.safe.com/ideas/directory-and-pathnames-reader-skip-invalid-paths-40791
Sounds like when scanning your network drive, the reader was hitting write-protected paths (along with hidden/system/invalid folders) and erroring out instead of just skipping past them, which meant working around it by pre-filtering folders you weren't interested in scanning in the first place.
I'd encourage other users running into this to upvote for a future inclusion in FME!
