Want to convert 3 character month to 2 digit month
aaron
Forum|alt.badge.img+10
I am trying to convert a three character month to a two digit month (e.g. - Mar to 03) using FME 2016.1 (build 16492). Should be easy enough using the DateFormatter but the converted value returned is always 01. I think my parameters are set up correctly. Screenshot attached. Any ideas?
Thanks,
Aaron
Best answer by ebygomm
I think the DateFormatter in 2016 only works on dates, so you can convert 01-Jan-2018 to 01-01-2018 but not just the Jan element on it's own.
There are a number of other ways to convert the months to their numeric values if it's just months with no day and year, e.g. attributevaluemapper
Or appending next in front of your 3 letter month and putting that through the date formatter using auto as the source will work too
chrisatsafe
  • January 8, 2019
Hi @aaron,
Not sure why the DateFormatter isn't giving you the correct output but it works with the DateConverter using the following parameters:
Input
Output
Here is a sample workspace: 2016.1_DateConverter.fmwt
Forum|alt.badge.img+34
  • January 8, 2019
aaron
  • January 8, 2019
Thanks @egomm and @ChrisAtSafe, both of your solutions work. I appreciate it!
Aaron
  • January 9, 2019
chrisatsafe wrote:
Hi @aaron,
Input
Output
FYI, the images are broken...
  • January 9, 2019
An alternative solution would be to use the AttributeValueMapper.
jkr_wrk
Forum|alt.badge.img+29
  • January 9, 2019
This would be my choice for this kind of problem. But the DateConverter could be more robust because it can deal with oct,Oct,10,okt differentiations.
  • January 9, 2019
Yes, it would absolutely depend on the input data.
chrisatsafe
  • January 9, 2019
TY, re-uploaded the attachments.
