Count (add up) empty values from a diffrent row
  • Oct 8, 2025 7:50 AM UTC
  • 5 replies
  • 143 views
kevink
Forum|alt.badge.img+3
This is the source table. The verblijfsbagid is a unique number of a building. Where the colum leegstand = J, i want a value in the colum leegstaand_maanden. The first empty row is 1 then 2 then 3 etc. I used diffrent transformers, like neigborfinder but it didnt work.
Here under is the output that i want to see (red numbers):
Best answer by takashi
In that case, as ​@nielsgerrits  mentioned, a combination of Enable Adjacent Feature Attributes option and conditional value setting works for you.
nielsgerrits
Forum|alt.badge.img+67
One way to do this is to use an AttributeCreator where under Advanced Adjacent Feature Attribues is enabled. This way you are able to fill a row based on a value in a previous row.
Then use Conditional Value. How I configure this is to create a mockup with formulas in Excel, and then tranplant the logic from excel to the conditional value.
  • Oct 8, 2025 8:24 AM UTC
Hi ​@kevinkies ,
A possible way is, separate the data flow into two streams for LEEGSTAND = J or not with Tester and add sequential number attribute starting with 1 to the features passed the test with Counter (Count: LEEGSTAND_MAANDEN).
Alternatively, you can update LEEGSTAND_MAANDEN with a conditional value setting in AttributeManager, using @Count function like this.
kevink
  • Oct 8, 2025 9:26 AM UTC
Thanks ​@takashi it works fine if there in order with no leegstand=N in between. U see the leegstand J or N is not always in order after each other:
here u see row 72-73-74 with yes and de conditional value works fine. Further in the table J will come again, but i need that he counts again from 1. Like here below:
it looks difficult the make that possible
  • Oct 8, 2025 10:00 AM UTC
kevink
  • Oct 8, 2025 6:15 PM UTC
it works fantastic!
