Export Project with Automation containing wildcard
  • Sep 19, 2025 7:59 AM UTC
  • 163 views
veschwab
Forum|alt.badge.img+26
I’m trying to create a project that contains an automation in which a workspace is using a wildcard in a filepath. The filepath looks something like this: SHAREDRESOURCES/DATA/FOLDER/**/*.csv
Fme Flow does not seem to like the wildcard in the filepath as I am guessing it wants to have a proper file to take in the dependencies and add to the project.
I could manually just choose a dummy file to be able to make the project work but that would mean I would manually have to change the filepath later and I would like to do as little manual steps as possible.
Is there any way around it? Can I maybe exclude specific dependencies somehow?
Best answer by alexbiz
Hey Vera,
I think it might be worth to submit that as an issue 👍
veschwab
  • Sep 19, 2025 8:30 AM UTC
Found a workaround to use a Directory and File Pathnames reader instead so I don’t have to use a wildcard in the file path :)
alexbiz
Forum|alt.badge.img+35
  • Sep 19, 2025 8:51 AM UTC
Hey Vera,
veschwab
  • Sep 22, 2025 6:16 AM UTC
Hey Vera,
Will do that, thanks! :)
itsmatt
Forum|alt.badge.img+48
  • Sep 22, 2025 11:40 AM UTC
I’ve found the same thing (in the Amazon s3 Bucket node) - in my case though it’s for a folder that doesn't need to exist - the automation will create the (temporary) folder:
$(FME_SHAREDRESOURCE_TEMP)/<productname_uploads>/{event.id}
I haven't bothered looking into a workaround for this yet - but certainly notable.
