Volume Calculation
  • Jan 30, 2013 6:45 PM UTC
  • 95 views
Hello FME Team, I was wondering if anybody has calcuated Volume of a pipe before? I have a Water network of pipes in GeoMedia and would like to calcuate the volume and output it as a new attribute on the existing feature class.  I have Pipe Length & Pipe Size to play with for attributes.
Thoughts?
philippeb
Forum|alt.badge.img+23
  • Jan 30, 2013 6:48 PM UTC
VolumeCalculator?
  • Jan 30, 2013 7:38 PM UTC
No Philippe, their is only the VolumeUnitConverter,  which works if you have a column with the volume already calculated and want to convert it to another unit of measurment.
philippeb
  • Jan 30, 2013 9:16 PM UTC
Which version of FME dow you have? In FME2013 I have VolumeCalculator. VolumeUnitConverter is from the FME Store.
Anyway, I would use the ExpressionEvaluator to simply make this :
v = h?r2
h would be your length
r would be the size
