VertexCounter transformer giving incorrect vertex count on line segments containing arcs.
  • Apr 23, 2019 4:49 PM UTC
  • 30 replies
  • 268 views
Show first post
Forum|alt.badge.img+54
  • Apr 29, 2019 8:13 AM UTC
I think a PythonCaller with this check should work:
geom = feature.getGeometry()
if isinstance(geom, fmeobjects.FMEPath):
    # feature geometry is an FMEPath instance
I was thinking of a non-python solution. It seems strange that you can't filter out paths when there are quite a few cases where you might want to treat them differently. I can fudge it with a combination of a GeometryPropertySetter and GeometryPropertyExtractor but i'm surprised there's not a better way
  • Apr 29, 2019 8:19 AM UTC
Unfortunately I'm not aware of any non-Python solution either. I agree that it would be handy if e.g. the GeometryFilter allowed you to check for path.
mark2atsafe
Forum|alt.badge.img+59
That's another one I'll raise with the developers. Seems crazy there is no way to tell if a feature is a path. Not even fme_type or fme_geometry will do it.
mark2atsafe
Filed as an enhancement request. The only other way I can see is to use GeometryExtractor to output XML and then check for the <path> tag.
  • Apr 29, 2019 3:10 PM UTC
My fudge was to set a geometry name then use the GeometryPropertyExtractor to only extract path - only paths come out the extracted port then
