Autodesk AutoCAD Map 3D Object Data Writer and custom hatches
  • Jun 19, 2025 8:41 AM UTC
  • 159 views
thierry
Forum|alt.badge.img+3
Hello, i saw this in FME documentation :
The ACAD format writer will look for custom hatch patterns in custom <filename>.pat files located in folder specified by the ACAD operating system environment variable, or in the related folder for any installed AutoCAD product.
The REALDWG format writer will look for custom hatch patterns in custom <filename>.pat files in the <FME install folder>/plugins/realdwg/Support folder. Predefined patterns can be found in the acdb.pat file in that folder, and additional patterns can also be added to that file.”
The Autodesk AutoCAD DWG/DXF Writer is fine : i get custom hatch patterns in my dwg file. (didn’t try REALDWG Writer)
But when i use the Autodesk AutoCAD Map 3D Object Data Writer, i get the warning :
“AutoCAD Writer: The combination of pattern type 'Custom-defined' and pattern name 'MYHATCH' was found to be invalid. Using a default predefined hatch pattern of value of 'SOLID'”
How are custom hatch patterns managed in this case ?  (using FME Workbench 2025.0)
Thank you.
Best answer by donalmateer
Hi ​@thierry!
I believe there is no support for custom hatches with the Map 3D Object Data Writer (and it defaults to a predefined hatch pattern). Is there a specific use case that you need to use the Map 3D Object Data Writer for?
I reccomend using one of the other writers that supports custom hatches - here’s an article comparing the different formats: AutoCAD DWG - Which format should I use?
donalmateer
Forum|alt.badge.img+13
  • Jun 23, 2025 11:05 PM UTC
Hi ​@thierry!
thierry
  • Jun 26, 2025 12:41 PM UTC
Hi ​@donalmateer ,
since  (thanks to the link you provided) i saw that the Map 3D Object Data Writer is a Realdwg writer extension), i put my *.pat files in the <FME install folder>/plugins/realdwg/Support folder and it works like a charm 👍)
Thank you
