Using snapper and line combiner to convert arc and a line
I'm trying to use snapper to snap a line and an arc together using their end points, then a line combiner to combine them into 1 straight line. however it doesn't appear to be working.
I can cheat and use a straight line instead, but I'd like to know the correct way of doing this, as I'd like to keep the data as accurate as possible.
Also, if the door comes out as *untouched* in the snapper, the rest of the process works, however if it snaps to form the half semicircle then the co-ordinate extractor and vertex creator fail to create a line.
Can anybody explain this to me?
virtualcitymatt
Forum|alt.badge.img+39
I'm not sure that I 100% follow what you're trying to do. Perhaps a screen shot of what you want at the end would help to understand the goal here.
Cheers
hkingsbury
Forum|alt.badge.img+55
  • August 19, 2021
You may hsve more luck first using the ArcStroker on the arcs to convert them to lines. Then you're dealing with two of the same geometry
