Use Attribute value as name for output folder
  • Oct 9, 2020 10:13 AM UTC
  • 10 replies
  • 209 views
lambertus
Forum|alt.badge.img+25
I extracted a zipped folder and searched within this folder for a PDF with an address. I would like to rename my unzipped folder with this address. At the moment I stored this address in an attribute.
Is there a way in FME I can rename the unzipped folder with this attribute value? Probably I need a Python Caller for that?
nielsgerrits
Forum|alt.badge.img+67
An alternative way to do this is using a SystemCaller. With this transformer you can run dos commands.
If you are opening the PDF files to find the name you will probably have to us a shutdown script. The reason being you will have a sharing violation due to FME having the file open and the rename will fail. If the file isn't open, you can either a system caller or a shutdown script. They both work equally well.
Shutdown guide
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_QuickTranslator/Workbench/Startup_and_Shutdown_Python_Scripts.htm
lambertus
  • Oct 9, 2020 1:49 PM UTC
Hi guys, thanks for your answers. I tried to create a new folder first which I could use to put my unzipped content in. Later on I could probably switch to rename my input folder. I used the following dos commands: However, no map was created in the Output folder.
SET a=D:\\Elbert\\Work\\Output\\
SET b=@Value(Name)
SET c="%a%%b%"
mkdir %c%
Outside FME using Command Window I used this commands (equivalent) which works perfect:
SET b=Name
SET c="%a%%b%"
mkdir %c%
Probably I need to do something extra to my variable b in the System Caller which is the FME part of my path?
SET b=@Value(Name)
SET c="%a%%b%"
mkdir %c%
SET b=Name
SET c="%a%%b%"
mkdir %c%
If the folder was created but no data was written, I would think you don't have the path specified in the writer in FME. You'll have to set that as a variable as well. It probably wrote somewhere but not to that folder.
lambertus
  • Oct 9, 2020 2:03 PM UTC
I did not use a writer yet. I expected to be the output of the SystemCaller a new folder in my Windows Explorer? This is my workbench yet.SystemCaller
Forum|alt.badge.img+54
  • Oct 9, 2020 2:06 PM UTC
Why not construct the folder path in an AttributeCreator first
directory = D:\\Elbert\\Work\\Output\\@Value(foldername)
and then use a system caller
mkdir @Value(directory)
What is the exit code coming out of the system caller? It should be 0 if the system caller was successful
lambertus
  • Oct 9, 2020 2:22 PM UTC
I get an error in Log Window about incorrect syntax. I used:
My exit code is 1.
  • Oct 9, 2020 2:36 PM UTC
My exit code is 1.
If you use mkdir with a hardcoded value does it work?
What is the value you are trying to use? Are there any unusual characters present?
lambertus
  • Oct 9, 2020 2:46 PM UTC
My exit code is 1.
I tried this hardcoded one:
mkdir D:\\Elbert\\Work\\Output\\Test
=> exitcode 1
Output in Log Windows shows:
The syntax of the command is incorrect.
SystemCaller_2: Failed to Execute `mkdir D:\\Elbert\\Work\\Output/Test
Somehow the slash changed from \\ to / in the Log Message.
lambertus
  • Oct 10, 2020 9:45 AM UTC
Hi guys, I found the solution :)
The trick was that the dos command need to be enclosed in quotation marks.
The final, working command was this one: "mkdir D:\\Elbert\\Work\\Output\\Test"
Beside that I found out that one needs to use extra quotation marks around your path in case the path contains spaces.
