Hi @kimburrows1242
There might be a confusion between the "fme_feature_type" attribute and the "autocad_layer"/"autocad_layer_name?" attribute with one overriding the other.
Right after the Schemamapper:
1. Does the features have a _schemamapper_rowid related to a line in the excel-file?
2. What is the value of fme_feature_type and autocad_layer? Is it changed?
sigtill wrote:
Hi @kimburrows1242
Yes, it does bring up this column _schemamapper_rowid and it has values in it (a line of numbers from 1,2,3 etc..)
fme_feature_type and autocad_layer seem to be exactly the same
My lookup needs to take the autocad_layer and look up the new feature class name (which it will be called in the GDB once written out).
I've manged to get some screenshots for you, have a look and let me know where you think I'm going wrong.
1st - Schema Mapper settings (I have tried different ones in here too)
2nd - part of the lookup table
3rd - Attribute Exposer Settings
4th - Schemer Mapper Row IDs
5th - Part of the output attributes from the last Schema Mapper run
sigtill wrote:
Hi @kimburrows1242
I just tried a
Map Feature Types with Autocad_layer -> FeatureClassName
It hasn't done them all but it's definitely just worked, however it's exported the FeatureClassName under the title fme_feature_type. It's not done them all but it's done a significant amount. The _schemamapper_rowid has changed to, it only has a few values in there now.
It all seems like it's almost correct.
Another good option would be to use the DatabaseJoiner transformer to join the information of the spreadsheet to the DGN/DWG file.
Using the autocad_layer/igds_level_name is tricky in case of an exploded block/cell. There can be a mismatch between the layer the block is on and the layers that contain the block elements (same for cells in the DGN file).
I would recommend using the fme_feature_type of the DWG/DGN source as that contains the layer/level of the block/cell.
Hope this helps.
Hope this helps.
This worked, however I couldn't expose the fme_feature_class int he DWG reader, I exposed the fme_feature_type, and this seemed to work for nearly everything. I'll keep testing and see. Thank you.
Sorry, typo. Should have been fme_feature_type. I changed it in the answer.
This does work for the majority but I am still getting errors, even though I've take the ones that did not merge and added them into the lookup with a FC name. It's still treating them as errors. Any idea why?
This still doesn't work, even though I'd created a lookup with an exact replica of layer names. Can anyone shed any light?
Hope this helps.
sigtill wrote:
Hi @kimburrows1242
